I need a option [do not auto-close FAYT field bar when mouse clicks outside the input field]
I have input a command in the FAYT field at the bottom, then I want to select another file and change some parameters of the command,
but when I clicks outside the input field, the FAYT field bar will be automatically closed.
Although I know I can use ">" to activate the field again, and press UP key to load commands history,this is still not so convenient.
I need a option so that the FAYT field bar can be pinned and not be automatically closed,unless pressing ESC key or Clicking on X button on the right.
We've added this for the next update. Thanks for the suggestion!
