Here is what i use. The code asks for extra confirmation on certain folders. So far it works alright. But i wonder, why the Delete REMOVECOLLECTION=auto SHIFT RECYCLE bit doesn't work as expected.
I guess, there is some flaw in my code.
I'm a bit confused by what you're trying to do here.
Do you really want six confirmation messages in one button, using both @confirm and Confirm?
Is Confirm a script command? It's not built-in.
Have you tried simplifying things, to see if the problem is actually the line you think it's on, not one of the others? e.g. If Confirm is a script command then it might be deselecting the file before it gets to the Delete line, or it might be aborting the whole command.
Some user from the forums had helped me with that code, so i guess there is some script. The multiple confirms are ok, i just wonder, why the other part is being ignored. I had those extra confirms because i am using the keyboard a lot, and feel a bit paranoid about accidently deleting very important stuff, if i hit the wrong key, which happened back then. That's why i have requested for those special commands. I will try out some variations, simplifying stuff, to narrow down the source of that issue.
How about cutting back on the edibles on Weedsday?
Alternatively you could use a script that tells you what you are going to delete:
function OnClick(clickData) {
var dlg = clickData.func.Dlg();
cmd.deselect = false;
var deleteMessage = 'Files to be deleted:\n';
var k = cmd.files.count;
if (k > 100) {
deleteMessage += '\n... very very many files: ' + k + '\n\nWatch out!';
} else {
for (var e = new Enumerator(cmd.files); !e.atEnd(); e.moveNext()) {
deleteMessage += '\n' + e.item();
if (dlg.Request(deleteMessage) == 1) {
cmd.RunCommand('DELETE QUIET');
Yeah, cool. What would be great, if it would ask me twice (asking just once is for normal paranoids only ), and if possible, to include a list of paths i can edit manually in the script, since for most of my data i'm not too much worrying about. Only my own photographs and part of my music collection are important, because i only back it up every now and then, so i might suffer, when my clumsy fingers do the wrong thing.
In the meantime i will replace that old script with your version. Thanks a lot!
I just noticed it, i like the part with the "many many files".
I had a closer look at the original button and got a bit confused. So I downloaded the Confirm command from here for a more detailed inspection.
Tip: Change MSG="wirklich löschen?" "\n" to MSG="wirklich löschen?\n" and the command will work properly and display all selected files (and not just ask "Proceed?").
Without the Confirm command the button will work normally and only remove files from a collection and not delete them. So somehow the use of Confirm replaces the items in a collection with the real files. I had a look at the JScript of Confirm but couldn't find the cause. Calling Mr @tbone for help!
As for the script above: I'll post a new version with the restriction for certain paths a bit later.
// https://resource.dopus.com/t/i-need-some-help-with-my-delete-button-code/35295
var dangerousFolders = /H:|K:\\Bilder|L:|M:|N:|coll:\/\//i;
var isDangerous = dangerousFolders.test(String(tab.path));
if (isDangerous) {
cmd.RunCommand('Play FILE="/windows\\Media\\Windows Notify System Generic.wav" QUIET');
if (k > 100) {
deleteMessage += '\n... very very many: ' + k + ' files.\n\nWatch out!';
} else {
cmd.RunCommand('Delete REMOVECOLLECTION=auto');
} else {
cmd.RunCommand('Delete REMOVECOLLECTION=auto SHIFT RECYCLE');
