Just trying to understand how backup and restore works with icons. I did a backup and restore without selecting
"Replace existing configuration completely"
So on the restore, what exactly happens with the icons ? Where does it put them by default from an .ocb file? once restored...
or do I need to do a separate backup of my own icons folder, my understanding from manual is that they are embedded into the backup file?
Standalone PNG files used as toolbar icons will not be included in the backup unless they're inside icon sets (in the Icons folder) or stored somewhere like the User Data folder (where you can put anything you wish and all the contents are backed up).
