Here is the icon pack for the two toolbars in my Opus 10 Tutorial.
You can also download and install the entire toolbars in a couple easy steps (instead of installing buttons one by one).
Only two of the icons are "mine" (the Rename icon and the Opus Styles icon).
The others are by various designers, all properly credited in the IconAuthors.txt file, along with the license terms.
(Not a lawyer, but if I understand, they're free to distribute for non-commercial use. But you'll see in the file that each icon has its own terms.)
Only including the 24x24 at this stage as it's what I'm using. Might make a large version if there is interest!
Wishing you all a beautiful day. opus-icons.zip (31.3 KB)
What setting did you lose?
I'm sure you know that in customize mode, you should be able to right-click the toolbars, hide them and show the original ones.
Let me know if you need any help.
Over time, as you use the toolbars, if you have any thoughts about things you would add or change to make it more "ergonomic", please shoot me a message some day, as I'm keen to hear other ideas.
