I recently installed Nitro 10 Pro and the icons showed correctly in DirOpus. I then uninstalled Acrobat 11. When I rebooted, the icons for PDF files show in DirOpus as plain white, whereas in explorer they are the correct colour. How do I get DirOpus to show the correct coloured icons? I have attached two file showing the icons.
Uninstalling Acrobat probably deleted parts of the .pdf file type in the registry. Explorer is a bit more forgiving of broken file types than Opus in some cases (and vice versa in others, I expect).
If you reinstall Nitro it will probably repair the registry settings. You may need to reboot after reinstalling it.
Reinstalling over the top of itself should be enough.
That worked. Thank you.
