hello,
I use directory opus for some time with XP and I never had any worries. Since I have vista, my icons in Explorer does not normally.
In XP, they are 48x48, but with Vista, not to have them in 48x48, 32x32 are in.
I hate 32x32 icons because they are too small. How can I do that in vista they are 48x48. I hope I was clear enough in my explanation.
when I met great mosaic icons or the icons are still small. by the records against job and trash, an option appears in "icon mean, and then the icons appear in big (strange). by against this option is only for desktop and trash panel.
I am still looking.
I'm not sure, but DOpus probably doesn't use the correct icon size in Large Icons View in Vista? Windows Explorer uses 48x48 icons,
even when you set the view mode to 'normal icons'. DOpus uses 32x32 icons, even in Large Icons View. But when you browse to
the desktop in DOpus, the 48x48 icons are used in Large Icons View:
