@ifpath:coll://(Duplicate Files|重复文件)
Select DUPES
@ifpath:else
Select ADVANCED
when not in the path "coll://Duplicate Files", the botton is disabled.
How to make "Select ADVANCED" work?
Select DUPES
@ifpath:else
Select ADVANCED
Add @enableif:=true to make it always enabled
@enableif:=true
Select DUPES
@ifpath:else
Select ADVANCED
@ifpath is the culprit here. Use the Evaluator instead.
Select {=RegExS(source, "coll://Dup") ? "DUPES" : "ADVANCED"=}
I see.
It is "Select DUPES" result in the button being disabled in non "coll://Duplicate Files" path.
It's not @ifpath: problem.
Another solution: put "Select ADVANCED" first.
@ifpath:!coll://(Duplicate Files|重复文件)
Select ADVANCED
@ifpath:else
Select DUPES
