Image conversion: Preset filename suffix is ignored
I changed the default 1024x768 image conversion preset to append the suffix "-1024" to images. However, Directory Opus still applies "-large". I remember changing this a couple of months ago, and back then it did work (once or twice?), but then reverted back to "-large". I just did some testing and changed the presents multiple times, but it sticks with "-large". I guess this is a (albeit minor) bug.
Thanks! This will be fixed in the next beta.
