I tried more than one pdf created with Abbyy Finereader 12 (last version). In attachment an example without OCR, but I tried also with OCR files.
There is no way to save with DO some metadata: in particular Tags and Title are not retained. Comment field instead seems ok. The pdf is v.1.5, which is not the last Acrobat version. Can someone explain?
Thanks.
test finereader and DO.zip (290 KB)
