I'm thinking this one may be asking too much - I've searched the forum and Help without getting even close. Is there any way to create a Style (e.g. a basic one - just designated columns and sort order) that will apply only to the active display in a Dual Display configuration?
For example, one go-to Style for me is called Modified and presents a group of columns including the Modified date, by which the list is sorted. Another is called Default, a different group of columns sorted alphabetically. And so on.
I'd like to be able to apply these Styles only to the active side of the dual display, leaving the format of the other side unchanged.
I recognize that in creating a Style one chooses either or both sides of a dual display to apply formatting to. Just wondering if there's a workaround, other than creating two of each Styles, one for left and one for right ... Thanks!
