Individual Groups not behaving as expected
In the documentation for 12.10, it says this of the new Individual Groups option:
Instead of A-H you would have A, B, C, D, E, F, G, H
However when I group by Filename and turn on Individual Groups, I get a separate group for every single file rather than groups like A, B, C, D, E, F, G, H
How can I get a group for each first letter like this without creating a custom column?
The example in the manual could be better. The option creates a separate group for each distinct value in the column you're grouping by. It's intended for things like comments and tags.
Creating a custom column for what you want is easy:
function OnLetter(scriptColData)
	scriptColData.value = scriptColData.item.name.substr(0,1).toUpperCase();
FirstLetter.js.txt (918 Bytes)
Command to toggle grouping by that:
@toggle:if Set GROUPBY=scp:FirstLetter/Letter
@if:Set GROUPBY=scp:FirstLetter/Letter
Set GROUPBY=off
@if:else
