InfoTip does not work in DOpus
if you change a folder icon in XP it creates a desktop.ini file in that folder, if you then edit that .ini file and add
InfoTip=my comment here
at the end of the .ini file then when you hover over the folder
"my comment here"
is displayed like a tool tip
this is working for me in windows explorer but not in DOpus
ds
If you edit the Opus tool tip for All Folders in the File Type editor and add {infotip} to the definition it might pick this up.
well that did work for a local drive but not on a mapped drive
but windows explorer works on the mapped drive
Check that you have InfoTips enabled for network drives:
amazing, thank you
there are so many settings !
