According to 8.1.0.6 changelog:
If filename extensions are hidden in Lister, inline rename no longer fails to select the text after a '.' in the filename (e.g., test.one.txt -> .txt would be hidden, in inline rename, previously only 'test' would have been selected automatically).
How do I get this to work ?? I still see test and not test.one.txt when I press F2. Do I have to set it in prefs somewhere ????
Thanks in advance
