At the moment @script only works with Rename. You can't use it on its own.
You have to either use this technique or put the script in a file and call that from Opus as if it was an external program.
Is AutoIT a language or does it expose some scriptable objects (like AutoItX3.Control) to other languages like VBScript? What you've written looks like VBScript and if so then you're doing it wrong. Have a look at one of my example VBScript Rename functions to see how they create and use the Shell and Filesystem objects.
It is a language and it exposes functionality via com and dll interfaces. (ActiveScripting).
I've actually pasted an Adobe InDesign vbscript in a button via @script vbscript and it works perfect (I'm aware that this is unsupported). I'm just checking other languages that I can use that have different functionality.
AutoIt has a LOT of very cool GUI features that could extend Opus greatly if If they could communicate via a plugin (which I asked about before).
If Powershell could be integrated like the batch file integration in functions that would be cool.
From looking via Google, AutoIT is not a language. It exposes some scriptable COM objects that you can use from ActiveScripting languages such as VBScript.
You'd do something like this, I expect:
[code]@script vbscript
Option Explicit
Dim oAutoIt
Set oAutoIt = CreateObject("AutoItX3.Control")
