MG250
July 31, 2026, 9:00pm
1
I often end up with duplicate tabs in my workflow. Is it currently possible to perform the following using an internal command?
Close all duplicate tabs (leaving only the first instance of each tab).
Close the duplicate tabs of a particular tab (leaving the selected tab open).
If not, could these be added as possible values for the TABCLOSEALL argument? Thank you.
I would use this functionality to add these buttons to the folder tabs context menu.
This could be done with some scripting.
You'd need to define a few more things: acting only on current lister (provably)? Only on current pane? Based on the tab folder or tab name (which can be changed)?
Jon
July 31, 2026, 9:57pm
3
There's a script for it here:
Overview
This script runs whenever a new lister (main window) opens, and will automatically close all tabs for folders which are already open in the same window.
For dual-display listers, a tab is only considered a duplicate if it is on the same sid…
David
July 31, 2026, 10:01pm
4
MG250:
I have used @Leo 's DeDuplicate Tabs for quite some time.
It is simple and works quite well.
I use the stand alone clickable version.
I see @Jon has posted as I was typing.
Here's my copy of the working button.
Close Duplicate Tabs.dcf (2.8 KB)
