Is a Right Click / Select All possible?
Vist 64bit | DO v9.1.1.0.3156.x64
One of the things I dislike about Windows Explorer is the lack of a "Select All" selection in the right click menu. A fellow named Ramesh on the Vista.General NewsGroup wrote a little registry routine that solved that problem for me.
Is there a way to get that functionality in Opus9? I process hundreds of photographs daily, and I don't want to have to take my hand off the mouse to go to a menu, or type ctrl a
I've been using Opus9 trial for about 3 hours and boy, am I impressed! - Help Appreciated - IM
Just add select all commad to default folder context menu.
To add commands to the default files and folders context Menu:
Click Settings -> File Types -> Select All Files and Folders -> Edit -> Click the Context Menu Tab ->
New -> Type: Run an Opus Function -> type the following code: Select ALL -> Click Ok
To add commands to the default Lister Menu:
Click Settings -> Customize -> Context Menus Tab -> Select Lister Context -> Show -> Right Click the Menu ->
New -> New Button -> Right Click the new button -> Edit -> Function: Select ALL
You could also just add a new button to the toolbar with the same code:
Right Click the Toolbar -> Customize -> Right Click the Toolbar (again) -> New -> New Button ->
Christiaan & Xyzzy - Got it, thanks for your help! - IM :slight_smile:
