I use Classic (now Open) Shell for my start menu. Is Opus compatible with it? (I know that it will replace the Explorer that comes with Open Shell, and that;s OK as long as I can still use the Start Menu features.)
We have no idea There's a free trial - give it a try!
I've been using Open Shell for a while, no issues whatsoever.
Same here, but I only install the start menu part of Open Shell,
I use Open Shell for the start menu and there are no issues with DO.
Many thanks to everyone who has responded. I've just installed DO and will give it a try. I'll plan on reporting back here in a couple of weeks with my experiences.
