Is it possible to have two Status Bars?
Is it possible to have two Status Bars at the bottom of a Lister? My current Status Bar looks like this:
I would like to remove the "dopus.exe" (the currently selected file or folder) and the "C:\Program Files\GPSoftware\Directory Opus\dopus.exe" part (the full path name of the selected file or folder) from my current Status Bar and have it instead put in a top Status Bar.
I am having problems where I click on a file in a Lister, but the file I click on doesn't actually get selected, so I added the {sel:name} and {sel:path} codes to let me visually verify that the file or folder that I want to select has in fact been selected.
Thank you for your help.
You can have one status bar below each file display, for a total of two.
You can't have two status bars for one file display.
