Is it possible to inverse regex filter?
Have set a regex filter. Now I would like files that do -not- match that filter.
Is that possible - if so, how?
Thanks.
Can be done using regex's negative lookahead asserts for the general case, but there's often an easier way to invert a pattern, depending on what the pattern is.
You could rewrite the filter with the evaluator and invert the result.
So
^2
would turn into
=!RegExS(name, "^2")
First of all: sorry for the late reply. One way or the other I didn't receive a notification.
Thanks for the replies.
Example:
Blah blah- 20102002 143124.doc
Blah blah grey.doc
Blah blahBlah blah-05122001 105640.pdf
Blah blahBlah blahBlah blah-05122001 105640.pdf
Blah blah-1SblueA C.doc
Blah blahBlah blah-1SA A.doc
Blah blah w953 02052001 210857.xls
Blah blahBlah blahBlah blah red.doc
Blah blah 27041999 193542.xls
Blah blah 24041999 003057.xls
Blah blahBlah blah stop.doc
Blah blah green 13072013.doc
Have been busy myself trying to get the right regex that may match lines -not- containing date, or date-time.
It may read something like: ^(?!.*(?:\d{2}-?\d{2}-?\d{4})(?: \d{6})?\.[^.]+$).+
However, probably this is not supported by Opus filter, so I gave up and let it rest.
Thanks again.
The regex appears to work correctly.
Still, a flag such as Set QUICKFILTERFLAGS=inverton to easily invert an existing filter would be a useful feature.
