Is there a usage case for Synchronise to compare by name
As title.
Scenario - 2 folders with same named files, one folder large images the other small images, some of the smaller images have been deleted and would like to synchronise (delete) the same named files in the large folder.
Sounds like a job for these bad boys:
Those only copy, and won't delete anything (except to overwrite things).
Edit: I was confusing them with something else, apologies. They don't copy or delete, just select, of course.
Great. thanks @lxp. Using Select Source Selection to Destination and then Inverting the selection will give desired result.
