Is there a way of editing tags inline?
Is there a way of editing tags inline, the same way we edit file and folder names?
What I mean is double click on a file or folder name allows me to edit it but to edit the tags I have to open the Metadata Pane.
Thank you,
D
Only the ratings tag. The others have to be edited via the metadata panel, metadata dialog, or pop-up prompts.
That's what I was afraid of. :slight_smile:
Thank you for the quick response,
D
