Is there a way to add conversion of .webp files to the images context menu?
Is there a way to add conversion of .webp files to the images context menu? Such as to convert them to .jpg or .png?
At present my right-clicks aren't recognizing .webp as an image file.
No issues here (DO13 beta). If you haven't already, add the .webp file type to DO, then add .webp to the images file type group. Once done, DO should recognize the file as an image on right click and allow you to convert the file.
References:
File types: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Filetypes.htm
File type groups: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Groups.htm
