...that only takes files created or modified after a certain date but maintains directory structure? When I use Find, thinking that I can 7z the results, they appear not quite to be adhering to the original dir structure.
Thanks as usual Leo That worked perfectly. I created the start of my 7z file, then opened it in a lister and filter copied the rest of the files into it.
