Hi, I just want to know if there's a workaround for fix this problem.
If you use a Go command and the right away a Select command, but in Preferences the "always select first item on list" option is on, the Select command doesn't work.
Just take a quick look.
Confirmed, thanks.
You might be able to work around it using DOpusRT /cmd for the Select command.
