Issue with Unicode Bidirectional Embedding Characters
I use Unicode bidirectional control characters to correctly display mixed RTL (Arabic) and LTR (English) text.
  • RLM/LRM characters work correctly everywhere in DOpus.
  • The newer isolate controls (LRI/RLI/FSI/PDI) display as little boxes and don't work. (They also don't work in File Explorer and voidtools Everything.)
  • The embedding controls (RLE/LRE/PDF):
    • File Explorer: Filenames display correctly.
    • voidtools Everything: Filenames and cell contents (e.g., the Description column) display correctly.
    Everything
    • DOpus dialogs (e.g., Set Description and Create Folder): Display correctly.
    • DOpus file display: Filenames and cell contents do not display correctly.
    2026-08-03_02-54
    • DOpus Metadata pane and inline rename mode: Display correctly only when the text cursor is placed in the field.
    2026-08-03_025448
Example
  • Without embedding controls:
الأسئلة المتداولة FAQ
  • With embedding controls (this is the intended appearance; RLE is placed at the beginning and PDF at the end):
<U+202B>الأسئلة المتداولة FAQ<U+202C>
Shown in Notepad++:
2026-08-03_041207
Is it possible for text containing embedding controls (RLE/LRE/PDF) to display correctly, as it does in File Explorer and voidtools Everything?
Windows itself doesn't support those yet.
This is a Windows bug, where it seems to ignore the directional characters if there is a zero-width space at the start of the string. We normally add that space to every string to work around another Windows bug where font kerning is inconsistent depending on which characters appear in the string. (Adding the zero-width space forces Windows to always go down one particular rendering path instead of the other, so the kerning is always consistent.)
You can turn that off by setting Preferences / Miscellaneous / Advanced: [Compatibility] patch_text_apis to False.
