Hi,
I'm experiencing an issue with video thumbnails not appearing in Directory Opus in a specific folder on my system.
Here's the situation:
- I'm using Directory Opus as my file manager on Windows.
- Thumbnails for both image and video files display correctly in most folders on my system, including on both the C: and D: drives.
- However, there's one specific folder where video thumbnails are not showing in Directory Opus. This folder is located on my D: drive and is the local sync folder for Proton Drive.
- In this Proton Drive folder, image thumbnails appear normally, but video thumbnails do not.
- When I open the same folder using Windows File Explorer, video thumbnails appear correctly, so the issue seems specific to Directory Opus.
I've checked various settings and tried refreshing the folder, but the problem persists. Any ideas on what might be causing this or how to fix it?
Thanks in advance for any help!
