Issues using Mounted ISO
I converted my Photoshop elements 13 DVD to ISO then when trying to install it from mounted ISO on DO11 give some weird errors
installing through explorer works fine. Odd thing is once I've run it through explorer I can then run it from DO fine while the ISO is mounted. If I unmount then remount and run through DO without first doing it from explorer it gives those errors.
How are you mounting it? With a third party tool?
just doubleclick in windows which mounts it, no external tools
Try going to Preferences / Zip & Other Archives / Archive and VFS Plugins and disable ISO there. That would have been overriding what double-click does in Opus.
That seems to have sorted it, thanks Leo
Does anyboday know how to disable opening Explorer after mounting an iso (autostart is turned off)?
I added the following command to the context menu of *.iso files. It mounts the files without opening explorer:
Button type: MS-DOS batch function
@runmode hide PowerShell Mount-DiskImage {filepath}
We'll make this the default in the next version.
@Kundal: Thanks, I found out that it only happens with DO-USB.
