Every width is set to Auto. In case you're wondering why there is a column for Company, I only added it to see if this really is the content type format that is combined with User Default
But when I enter a folder that contains SQL files, and it changes format according to a mix of its content and the User Default, something goes haywire, and the lister becomes "less useful":
I've resized the lister window to a manageable size so that everything I wanted to show fits on a relatively small screenshot. When it's maximized, the columns are similarly squished, and there's plenty of empty space on the right.
Checking the Folder Options, it shows that the width for some of the columns is changed from Auto to a fixed size:
Why does this happen? None of the saved formats contain those numbers for any of those fields.
Hi Jon,
Yes, that's on my 4th screenshot from the top, marked with the red rectangle in the bottom-right corner. I attached those screenshots to support why this should not happen the way it does. As you can see on the screenshot, the current format comes from User Default Format + Content Type "SQL Files". The previous two screenshots show those formats, neither of them having anything but Auto for their columns' width settings.
