When using a "stars" type column, I've noticed some issues with its width:
- It doesn’t auto-resize like other columns when opened; it always appears cut off.
- It seems to shrink in width when certain infotips (or other columns) are calculated.
Can you post the script? I tried with an evaluator column but couldn't reproduce it.
Sent.
It's because you haven't specified the "maxstars" value, so it doesn't know how many stars to autosize for.
Thanks. TBH, I thought it was 5 by default and was only used if you wanted to change that number to another value.
