Items in "Send To" menu not in alphabetical order
For some reason the items in my 'Send to' menu are not in alphabetical order in the Directory Opus context menu. Is there anyway to fix this or change the sort order?
Can you show a screenshot of the menu, in Opus and also in File Explorer for comparison?
yessir.
D Opus:
Windows Explorer:
Thanks! That should be fixed in the next beta.
