the image conversion dialog allows setting transparent colour for alpha in jpegs
and I thought jpeg had been updated to support this, (not sure if its a seperate codec, jpeg2000 or jpegxl ?)
but after conversion the jpeg images do not have alpha.
JPEG2000 and JPEG XL are both advanced image codecs, but they have some key differences:
JPEG2000:
Compression: Offers both lossy and lossless compression.
Quality: Known for high-quality image compression, especially for medical imaging and digital cinema.
Adoption: Widely used in specific industries but not as common for general web use.
Features: Supports alpha transparency, progressive decoding, and error resilience.
JPEG XL:
Compression: Also supports both lossy and lossless compression.
Quality: Provides better compression efficiency and quality compared to JPEG2000.
Adoption: Designed to be a universal replacement for many image formats, including JPEG, PNG, and GIF.
Features: Legacy-friendly, meaning it can transcode existing JPEG files without additional loss. It also supports alpha transparency and progressive decoding.
In summary, JPEG XL is a more modern and versatile format with better compression efficiency and broader applicability. However, JPEG2000 remains relevant in certain specialized fields. If you're looking for a future-proof, high-quality image format, JPEG XL might be the better choice.
(hmmm - asked copilot as was quicker than doing web search, but seems to be kosher )
