This the JScript button code for Iconmaker v2 which can be found in the Icons section of the forum.
// _____ _ __ __ _ ___
// |_ _| | | | \/ | | | |__ \
// | | ___ ___ _ __ ___ ___| |_ | \ / | __ _| | _____ _ __ __ __ ) |
// | | / __/ _ \| '_ \/ __|/ _ | __| | |\/| |/ _` | |/ / _ | '__| \ \ / // /
// _| || (_| (_) | | | \__ | __| |_ | | | | (_| | | __| | \ V // /_
// |_____\___\___/|_| |_|___/\___|\__| |_| |_|\__,_|_|\_\___|_| \_/|____|
// Button for making Directory Opus icon sets see post in the 'Icons' forum.
// LOGGING FOR Log() - SET TO FALSE TO TURN OFF LOGGING
var log = false;
// duplicateCheck, when true will prevent another dialog being displayed every time
// the button is pressed after the first time. In rare circumstances, for instance, when playing
// around with the code and putting in something that causes the program to abort due to syntax error
// the session variable 'duplicatedialog' might not be reset to false and clicking the button for the
// first time will do nothing. Session variables will be reset after a proper close of Directory Opus.
// You can turn this feature on or off :
var duplicateCheck = false;
function OnClick(clickData)
Log("Iconset Maker v2", "#4455ff", 1);
// OPEN THE 'OTHER LOGS' CONSOLE AND CLEAR IT
// if (log) {
// clickData.func.command.RunCommand("Set UTILITY=otherlog")
// DOpus.ClearOutput();
// GLOBAL VARIABLES
var iconName;
var iconArtist;
var iconCopy;
var iconLarge;
var iconSmall;
var xmlArray = [];
var pngArray = [];
var folderPath = clickData.func.sourcetab.path;
var montagePath = folderPath + "\\montage.exe";
// SESSION VARIABLES (Ends on DO exit)
// duplicate dialog check, return if dialog active
if (duplicateCheck) {
if (DOpus.vars.Exists("duplicatedialog")) {
Log("----> duplicatedialog variable exists (deleted on DO exit)");
if (DOpus.vars("duplicatedialog").value) {
Log("----> duplicate dialog - returning");
return;
} else Log("----> no duplicatedialog session variable present");
DOpus.vars.Set("duplicatedialog", true);
// CHECK MONTAGE IN CURRENT FOLDER ***************************************************************************
if (!DOpus.FSUtil.Exists(montagePath)) {
// Montage dialog init
var dlgMontage = DOpus.Dlg;
dlgMontage.template = "Montage dialog";
dlgMontage.LoadPosition("Foo_Dialog_Position");
dlgMontage.title = "Directory Opus";
dlgMontage.detach = true;
dlgMontage.icon = "info"
dlgMontage.Create();
dlgMontage.Control("static1").fg = "#00961e";
dlgMontage.Control("static1").label = "montage.exe is not in the current folder";
dlgMontage.Control("static2").fg = "#0000ff";
dlgMontage.Control("static2").label = "Click here to goto the imagemagick website to download it";
dlgMontage.Control("static3").fg = "#404040";
dlgMontage.Control("static3").label = "ImageMagick, invoked from the command line as magick, is a free and open-source cross-platform software suite for displaying, creating, converting, modifying, and editing raster images. \nIt includes a program called montage which can scale and stitch images together to make the two icon sheets Directory Opus uses.";
dlgMontage.Control("static4").fg = "#404040";
dlgMontage.Control("static4").label = "Download and Extract one of the portable versions of ImageMagick, \nthey are at the bottom of the downloads page.";
dlgMontage.Control("static5").fg = "#404040";
dlgMontage.Control("static5").label = "Make a folder somewhere and put montage.exe and the individual square PNG images of any size in it.";
dlgMontage.Control("static6").fg = "#404040";
dlgMontage.Control("static6").label = "and then use this button again.";
while (true) {
var msg = dlgMontage.GetMsg();
if (!msg.result) break;
if (msg.event == "click" && msg.control == "static2") {
DOpus.create.command.RunCommand("https://imagemagick.org/script/download.php");
dlgMontage.SavePosition("Foo_Dialog_Position");
if (duplicateCheck) DOpus.vars.Set("duplicatedialog", false);
return;
// montage exists continue ....
// CHECK THERE ARE PNG'S IN FOLDER ***************************************************************************
var regex = /\.png/i;
var collection = DOpus.FSUtil.ReadDir(folderPath);
while (!collection.complete)
var item = collection.Next();
// Read png names into pngArray[]
if (item.ext.match(regex)) {
pngArray.push(item.name_stem);
if (!pngArray.length) {
Log("NO PNG's IN THIS FOLDER", "#cc4952");
// PNG dialog init
var dlgPNG = DOpus.Dlg;
dlgPNG.template = "PNG dialog";
dlgPNG.LoadPosition("Foo_Dialog_Position");
dlgPNG.title = "Directory Opus";
dlgPNG.detach = true;
dlgPNG.icon = "info"
dlgPNG.Create();
dlgPNG.Control("static1").fg = "#00961e";
dlgPNG.Control("static1").label = "THERE ARE NO PNG IMAGES IN THIS FOLDER";
dlgPNG.Control("static2").fg = "#0000ff";
dlgPNG.Control("static2").label = "Copy images that will be converted to icons into this folder.";
dlgPNG.Control("static3").fg = "#0000ff";
dlgPNG.Control("static3").label = "\nAny images that are not PNG format will not be processed, they can be converted using the 'Convert' button on the 'Images' toolbar. Also, there is usually a convert image option in the context menu";
dlgPNG.Control("static4").fg = "#0000ff";
dlgPNG.Control("static4").label = "The images can be of any size.\nSquare images are best for icons though not necessary.";
while (true) {
var msg = dlgPNG.GetMsg();
if (msg.event == "click") {
DOpus.create.command.RunCommand("https://en.wikipedia.org/wiki/Portable_Network_Graphics");
dlgPNG.SavePosition("Foo_Dialog_Position");
return;
// png's present continue ....
// MAIN DIALOG INIT ******************************************************************************************
var dialog = DOpus.Dlg;
dialog.template = "Main Dialog";
dialog.LoadPosition("Foo_Dialog_Position");
dialog.title = "Directory Opus";
dialog.detach = true;
dialog.Create();
dialog.Control("static1").fg = "#00339e";
dialog.Control("static1").label = "Enter a unique name for the iconset";
dialog.Control("static2").fg = "#00339e";
dialog.Control("static2").label = "Large Icon Size";
dialog.Control("static3").fg = "#00339e";
dialog.Control("static3").label = "Small Icon Size";
dialog.Control("static7").fg = "#00339e";
dialog.Control("static7").label = "Artist";
dialog.Control("static8").fg = "#00339e";
dialog.Control("static8").label = "Copyright";
dialog.Control("static9").bg = "#ff0000";
dialog.Control("static9").fg = "#ffffff";
dialog.Control("static10").fg = "#3377be";
dialog.Control("static10").label = "PNG images only. Square ones. Any size.";
// sets some vars from Directory Opus persistant variables
function SetVars() {
if (DOpus.vars.Exists("session_iconName")) iconName = DOpus.vars.Get("session_iconName");
else iconName = "";
dialog.Control("edit1").value = iconName;
if (DOpus.vars.Exists("session_iconLarge")) iconLarge = DOpus.vars.Get("session_iconLarge");
else iconLarge = 32;
dialog.Control("edit2").value = iconLarge;
if (DOpus.vars.Exists("session_iconSmall")) iconSmall = DOpus.vars.Get("session_iconSmall");
else iconSmall = 24;
dialog.Control("edit3").value = iconSmall;
// init name with selected item if an 'iconset Maker' sub-folder is selected in source tab
var source = clickData.func.sourcetab;
if (source.stats.selitems > 0) {
// an item is selected in folder
var item = source.selected(0).name_stem;
var regex = /(.+) \((\d+)px & (\d+)px/; // 'folder name (22px & 33px)' captures folder name and two px values
if (item.match(regex) == null) {
// item does not match regex
SetVars();
} else {
// item matches regex
dialog.Control("edit1").value = item.match(regex)[1];
dialog.Control("edit2").value = item.match(regex)[2];
dialog.Control("edit3").value = item.match(regex)[3];
} else {
// item not selected call SetVars
SetVars();
dialog.Control("edit1").SelectRange(0,-1);
// sets artist and copyright from Directory Opus persistant variables
if (DOpus.vars.Exists("session_iconArtist")) iconArtist = DOpus.vars.Get("session_iconArtist");
else iconArtist = "Various";
dialog.Control("edit4").value = iconArtist;
if (DOpus.vars.Exists("session_iconCopy")) iconCopy = DOpus.vars.Get("session_iconCopy");
else iconCopy = "© 2022";
dialog.Control("edit5").value = iconCopy;
// MAIN DIALOG MESSAGE LOOP **********************************************************************************
while (true) {
var msg = dialog.GetMsg();
var err = 0;
var text = dialog.Control("static9");
iconName = dialog.Control("edit1").value;
iconLarge = +dialog.Control("edit2").value;
iconSmall = +dialog.Control("edit3").value;
iconArtist = dialog.Control("edit4").value;
iconCopy = dialog.Control("edit5").value;
if (msg.event == "click" && dialog.Control("button1").focus == true) {
Log("OK pressed");
if (iconName == "") err = 1;
else if (iconLarge == 0) err = 2;
else if (iconLarge < 12) err = 3;
else if (iconLarge > 256) err = 4;
else if (iconSmall == 0) err = 5;
else if (iconSmall < 12) err = 6;
else if (iconSmall > 256) err = 7;
else if (iconSmall > iconLarge) err = 8;
else if (iconSmall == iconLarge) err = 9;
else if (iconArtist == "") err = 10;
else if (iconCopy == "") err = 11;
switch(err) {
case 0 : Log("No err");
break;
case 1 : text.label = "Enter a name";
break;
case 2 : text.label = "Enter a size for Large icons";
break;
case 3 : text.label = "Large icons are less than 12px";
break;
case 4 : text.label = "Large icons are greater than 256px";
break;
case 5 : text.label = "Enter a size for Small icons";
break;
case 6 : text.label = "Small icons are less than 12px";
break;
case 7 : text.label = "Small icons are greater than 256px";
break;
case 8 : text.label = "Small icons are bigger than Large";
break;
case 9 : text.label = "Small and Large icons are the same";
break;
case 10 : text.label = "Enter a name for the Artist";
break;
case 11 : text.label = "Enter a Copyright";
break;
default : Log("default");
if (err > 0) {
text.visible = 1;
continue;
} else {
break;
} else text.visible = 0;
// ********************* END MAIN DIALOG MESSAGE LOOP ********************************************************
dialog.SavePosition("Foo_Dialog_Position");
if (dialog.result == 0) {
Log("Cancelled - closing dialog");
return;
// OK, CONTINUE .... ******************************************************************************************
var folderName = iconName + " (" + iconLarge + "px " + "& " + iconSmall + "px)";
var newSubFolder = folderPath + "\\" + folderName;
var fileNameLarge = "Large_" + iconLarge + "px.png";
var fileNameSmall = "Small_" + iconSmall + "px.png";
dialog.Control("static10").fg = "#009e33";
dialog.Control("static10").label = "Takes a few seconds, please wait ....";
Log("****************************");
Log("name = \t\t" + iconName, "#00861e");
Log("Large = \t\t" + iconLarge, "#00861e");
Log("Small = \t\t" + iconSmall, "#00861e");
Log("artist = \t\t" + iconArtist, "#00861e");
Log("copyright = \t" + iconCopy, "#00861e");
Log('Sub-Folder = \t' + (DOpus.FSUtil.Exists(newSubFolder) ? 'EXISTS' : 'NOT FOUND'));
Log('folderpath = \t' + folderPath);
Log('foldername = \t' + folderName);
// CREATE FOLDER, DELETE FIRST IF IT EXISTS ******************************************************************
if (DOpus.FSUtil.Exists(newSubFolder)) {
var command = "";
command += 'Delete ';
command += '"' + newSubFolder + '"';
command += " QUIET";
Log(command, "#f509e8");
clickData.func.command.SetModifier("noprogress");
clickData.func.command.RunCommand(command);
var command = "";
command += 'CreateFolder NAME=';
command += '"' + folderPath + '//' + folderName + '"';
// MONTAGE ***************************************************************************************************
function CallMontage(size, filename) {
var imagefilter = "*.png";
var montage = "";
montage += (folderPath + "\\montage ");
montage += '"' + folderPath + "\\" + imagefilter + '"' + " " ;
montage += "-geometry " + size + "x" + size + "+0+0 ";
montage += "-tile 16 -background transparent -filter Lanczos -quiet ";
montage += '"' + newSubFolder;
montage += "\\" + filename + '"';
clickData.func.command.AddLine("@runmode:hide");
clickData.func.command.AddLine("@sync:" + montage);
clickData.func.command.Run();
// Large icons
CallMontage(iconLarge, fileNameLarge);
// Small icons
CallMontage(iconSmall, fileNameSmall);
// CREATE XML ************************************************************************************************
function WriteIconList() {
var row=1;
var col=1;
for (var i in pngArray) {
xmlArray.push(' <icon name="' + pngArray[i] + '" row="' + row +'" col="' + col + '" />');
col++;
if (col > 16) {
col = 1;
row++;
// WRITE XML TO ARRAY
xmlArray.push('<?xml version="1.0" encoding="UTF-8"?>');
xmlArray.push('<iconset name="' + folderName.replace(/ /g, "_") + '">');
xmlArray.push(' <display_name>' + iconName + '</display_name>');
xmlArray.push(' <copyright>' + iconCopy + '</copyright>');
xmlArray.push(' <artist>' + iconArtist + '</artist>');
xmlArray.push(' <set size="small" width="' + iconSmall + '" height="' + iconSmall + '" filename="' + fileNameSmall + '">');
WriteIconList();
xmlArray.push(' </set>');
xmlArray.push(' <set size="large" width="' + iconLarge + '" height="' + iconLarge + '" filename="' + fileNameLarge + '">');
WriteIconList();
xmlArray.push('</iconset>');
// CONVERT XML ARRAY TO STRING
xmlArray = xmlArray.join("\n");
Log(" ");
Log(xmlArray);
Log(" ");
// WRITE XML TO FILE
var a = fso.CreateTextFile(newSubFolder + "\\Iconset.xml", true, true);
a.WriteLine(xmlArray);
a.Close();
// CREATE ARCHIVED .DIS FILE *********************************************************************************
var command1 = "";
command1 += 'Copy ';
command1 += '"' + folderName + '"';
command1 += " ARCHIVE TO ";
command1 += '"' + folderPath + '"';
command1 += ' CREATEFOLDER=' + '"' + folderName + '.dis"';
Log(command1, "#f509e8");
// MOVE TO FOLDER
var command2 = "";
command2 += 'Copy ';
command2 += '"' + folderName + '.dis"';
command2 += ' MOVE TO ';
command2 += '"' + newSubFolder + '"';
Log(command2, "#f509e8");
clickData.func.command.AddLine(command1);
clickData.func.command.AddLine(command2);
// ******************************************** END **********************************************************
// PERSISTANT VARIABLES
DOpus.vars.Set("session_iconName", iconName);
DOpus.vars("session_iconName").persist = true;
DOpus.vars.Set("session_iconLarge", iconLarge);
DOpus.vars("session_iconLarge").persist = true;
DOpus.vars.Set("session_iconSmall", iconSmall);
DOpus.vars("session_iconSmall").persist = true;
DOpus.vars.Set("session_iconArtist", iconArtist);
DOpus.vars("session_iconArtist").persist = true;
DOpus.vars.Set("session_iconCopy", iconCopy);
DOpus.vars("session_iconCopy").persist = true;
Log("END");
function Log(str, color, init) {
if (color === undefined) color = "#000000";
if (log) {
if (init) {
DOpus.Output("<font color=" + color + ">" + str + "</font>");
<resources>
<resource name="Main Dialog" type="dialog">
<dialog fontface="Arial Bold" fontsize="12" height="180" lang="english" width="252">
<control halign="center" height="8" name="static1" title="static1" type="static" valign="top" width="116" x="63" y="12" />
<control halign="left" height="12" max="31" name="edit1" type="edit" width="112" x="66" y="24" />
<control halign="right" height="8" name="static2" title="static2" type="static" valign="top" width="47" x="64" y="51" />
<control halign="right" height="8" name="static3" title="static3" type="static" valign="top" width="47" x="64" y="64" />
<control halign="left" height="12" max="3" name="edit2" number="yes" title="32" type="edit" width="19" x="114" y="50" />
<control halign="left" height="12" max="3" name="edit3" number="yes" title="24" type="edit" width="19" x="114" y="63" />
<control default="yes" height="14" name="button1" title="OK" type="button" width="50" x="68" y="156" />
<control close="0" height="14" name="button2" title="Cancel" type="button" width="50" x="134" y="156" />
<control halign="left" height="8" name="static5" title="px" type="static" valign="top" width="12" x="135" y="52" />
<control halign="left" height="8" name="static6" title="px" type="static" valign="top" width="12" x="135" y="65" />
<control halign="right" height="8" name="static7" title="static7" type="static" valign="top" width="19" x="44" y="91" />
<control halign="left" height="12" max="31" name="edit4" type="edit" width="112" x="66" y="90" />
<control halign="right" height="8" name="static8" title="static8" type="static" valign="top" width="33" x="30" y="109" />
<control halign="left" height="12" max="31" name="edit5" type="edit" width="112" x="66" y="108" />
<control halign="center" height="8" name="static9" title="static9" type="static" valign="top" visible="no" width="112" x="66" y="39" />
<control halign="center" height="8" name="static10" title="static10" type="static" valign="top" width="224" x="14" y="133" />
</dialog>
</resource>
<resource name="Montage dialog" type="dialog">
<control close="0" default="yes" height="14" name="button1" title="OK" type="button" width="50" x="101" y="155" />
<control halign="center" height="8" name="static1" title="Static" type="static" valign="top" width="224" x="14" y="10" />
<control halign="center" height="8" name="static2" notify="yes" title="Static" type="static" valign="top" width="224" x="14" y="30" />
<control halign="center" height="40" name="static3" title="Static" type="static" valign="top" width="224" x="14" y="43" />
<control halign="center" height="19" name="static4" title="Static" type="static" valign="top" width="224" x="14" y="93" />
<control halign="center" height="19" name="static5" title="Static" type="static" valign="top" width="224" x="14" y="116" />
<control halign="center" height="12" name="static6" title="Static" type="static" valign="top" width="224" x="14" y="139" />
</dialog>
</resource>
<resource name="PNG dialog" type="dialog">
<dialog fontface="Arial Bold" fontsize="12" height="139" lang="english" width="252">
<control close="0" default="yes" height="14" name="button1" title="OK" type="button" width="50" x="101" y="117" />
<control halign="center" height="8" name="static1" notify="yes" title="Static" type="static" valign="top" width="224" x="14" y="10" />
<control halign="center" height="40" name="static3" notify="yes" title="Static" type="static" valign="top" width="224" x="14" y="43" />
<control halign="center" height="19" name="static4" notify="yes" title="Static" type="static" valign="top" width="224" x="14" y="88" />
</dialog>
</resource>
</resources>
