As the title states: I'd like to keep my opus configs in sync between my laptop and desktop, as I'm frequently changing things and doing a backup → restore all the time is a bit frusturating. I know there are scripts to automate the backup process and that's fine, but I'm more wondering if I can just keep them in sync by using git(hub) or a file synchronization service like Box or OneDrive,
Even if you got the syncing right on the file level, you would still need to fully exit and restart Opus on both machines to keep both installation's config completely in sync. A few areas like Rename Presets and Script Add-ins might work without exit/restart, but that seems too little gain for too much effort and risk.
thanks. I just was hoping there was a faster way to mirror settings on the laptop.
