Labels checkbox does not uncheck
I have a path-folder format, for which I seem to be unable to uncheck the labels checkbox.
I..
  • Open the prefs window
  • Enter folder formats and open the path-format editor by doubleclicking
  • Switch to the "Labels" tab
  • Uncheck "Labels"
  • Close the format editor with "Ok"
  • Close the prefs window with "Ok"
Then I..
  • Reopen the prefs window
  • I switch to the "Labels" tab
..and the Labels checkbox is still checked. Is this related to some other setting or something else I'm not aware of?
Thank you for any advice! o)
I just tested it with a wildcard label, but it doesn't happen here. The box stays unchecked. You seem to use a special script related function, so does it happen
with other labels, too?
What do you mean exactly with "I use a script related function"? o)
The Labels checkbox does not uncheck for any folder format here, I just tried them all.
I wasn't sure, where the names are coming from (it only appears to be your own description). Anyway, you're right. I retested it und can now confirm that the
check box keeps coming back. Sorry for the confusion.
I can also confirm but if memory serves me correctly, this has already been reported.
Thanks for the report. This has been fixed for the next update.
