Launch more than one applications by a function
Hi,
To launch an application by an icon is very simple: cd "path" "path/appname.exe", so, as I need an icon to launch three applications, I wrote:
cd "path1"
"path1/appname1.exe"
cd "path2"
"path2/appname2.exe"
cd "path3"
"path3/appname3.exe"
but Dopus patiently waits for the app1 to close, then launches app2...
Could a kind soul explain how to tell Dopus to launch the three apps at once, (or maybe with a one second delay between apps)?
Thanks,
You could try using the @async: command for each program launch. This works for exterenal commands only.
Thanks, this works fine! And leads to another question:
cd "path"
"path/appname.exe" /minimized
fails to launch the app minimized. In help, I couldn't find any reference to other stuff than minimize Dopus itself.
With friendship,
Try @runmode=min as an additional switch.
Thanks a lot.
It didn't work, but neither did it with a windows shortcut with /minimized.
This means, I suppose, that this application is bugged.
Anyway, thanks a lot for your kind help.
Would you happen to know how to create a button creating a text file
containing the clipboard, into the active window, named with the 40 first acceptable characters,
and that wouldn't begin by a space.
I've abandoned this after tons of unsuccessful tries.
Man, Dopus scripting is not that easy !
With friendship,
