Launching Opus / Explorer Replacement
Hi. I'm new to Directory Opus and trying to figure out how to make it the default over Explorer in Windows 10. After poking around the manual and the web/forums for a while, it looks like I'm supposed to go to "Launching Opus / Explorer Replacement" in Preferences, but it's not there. I've included an attachment so you can see what I mean. Any help?
Directory Opus 12 v. 12.2 x64
Light Edition
Thanks!
John
It's only in the Pro version. Here's a summary of Light vs Pro.
If you want to test-drive Opus Pro you can do so free for 60 days here, and can go back to Light afterwards if you decide it isn't for you.
If you choose to upgrade to the Pro version, you can do so here, and the cost is just the difference between the normal Light and Pro prices.
[quote="leo"]It's only in the Pro version. Here's a summary of Light vs Pro.
If you choose to upgrade to the Pro version, you can do so here, and the cost is just the difference between the normal Light and Pro prices.[/quote]
Thank you!
