Hi,
i use more NAS Systems and many external Harddrives.
It it important to get the highest level of informations of the files.
I create more Layouts for every File-Type that i need the informations.
Here i show the Layout "Files" and "Photos"
Layout Files
Now it dont loose the path of my browsed locationsa and filders.
The Problems will be with Styles are the on created Menu Bars that i want to put on or off.
In Layout Files there will be Menü in grey, green, yellow and orange are needed.
In Layout Photos only need the grey and red Menü.
When i switch between the Layout with Styles then all Menus will be shown.
It is possible to put menus on and off in Styles???
I want to show only the menus for every file typed that are needed and not all.
You can edit your styles via Preferences / Layouts and Styles / Styles.
Double-click a style in there, and you'll see a Toolbar option. If that is turned off, the style won't affect your toolbars and menus at all. If it is turned on, you can select a toolbar (single toolbar) or toolbar set (multiple toolbars) to activate when the style is selected.
Toolbar sets can be made under Preferences / Toolbars / Toolbar Sets, and you can define whether they add to the existing/default toolbars when you use them, or whether they replace the existing/default toolbars.
Thank you,
i found to set a single toolbar but i dont have seen that i can define a multiple toolbars.
I will define a Set and see how it works.
A Last question for this post is the space between the areas.
when i switch between the styles then the areas will be reset???
The Folder structure and the area metadata dont need so many space.
It is possible to define how many space with are needed?
Or can save the last defines spacing by the areas?
