Licensing question for Dual Boot Desktop + Laptop
I have a question about how dual boot systems are treated under the licensing terms? I have a desktop with XP 32-bit and Win 7 64-bit (Dual Booting) and a laptop with Vista 32-bit. The way I read it I can install DOpus on the desktop and laptop with a single user license but there is no mention of multi booting pc's so - Can I install it twice on the same PC as well as my laptop under a single license ??
Regards
Mike.
Best to ask GPSoftware for a definitive answer:
gpsoft.com.au/Support.html
Ok I've done as you suggested and am awaiting an answer.
Regards
Mike.
I have received a reply to my web support query as quoted below:[quote]> I have a question about how dual boot systems are treated under the
Can I install Directory Opus twice on the same PC as well as my laptop
Regards
Mike.
Mike,
Thanks for contacting us.
This is not a problem. Opus is licensed on a machine basis not the OS so you
can use the same licence on dual or multiple boot systems.
__
Regards, Dr Greg Perry[/quote]
All sounds great so I think i'll be purchasing soon
:smiley:
Better sooner than later LOL
Such a great product it is endless ......
:smiley:
I remember the days when I had Directory Opus running on my Amiga 4000 - that was a few years ago !!
