I was surprised today to see that my license had expired for Opus 13.
It doesn't concern me much because i always want to support you guys -- i use the product all the time for personal use at my home.
But i am concerned because i have it installed on 2 or 3 machines in my home lab (not sure) and it's never been an issue.
My main machine is intentionally running an old version because i've setup some development around it and haven't tested a new version with it to make sure it works. Still using version 12.29.
Questions:
1 - Will i still be able to run 12.x?
2 - any changes to how the activation process works? I'm concerned that will pay for the maintenance and then run into issues with multiple versions or tighter restrictions on the number of machines it can run on.
The licence doesn't expire, just the ability to install updates released after expiry (if you don't renew). You can keep using the versions you already have forever.
It works today. So my question is about whether it is tightened. I'm not really up to speed on how the licensing works so i just know it's working fine now.
