Lister is unresponsive. I can scroll the list of files, but can't select them. The close button and other window controls, including resize and dragging the title bar to move it, do not work.
It may be unrelated, by I archived a folder with 7zip before this happened. I've not had this issue using 7zip before in Opus 13, or with Opus 12.
Edit: Correction, I was able to reproduce it by creating a 7zip archive and then deleting the directory that I just archived. I think it's the deletion that causes the freeze.
I added a folder to a 7zip archive via the 7zip context menu items.
I then deleted that folder by selected it in the lister and pressing shift-delete, as I normally do.
Directory Opus 13.5 Build 8871 x64
OS 10.0 (B:22631 P:2 T:1) SP 0.0
(Windows 11, up to date on patches)
150,000 files of mixed types, from source code to executables. I run Microsoft Antivirus, I've seen that cause performance issues with Thunderbird mail exports before.
