Lister column fixed width
Hi,
Is there any way to prevent lister columns width from changing each folder? I prefer the way Explorer lists files and keeps columns at width I set it. I do not mind column to get wider if needed but I definitely do not like the way it works here now, when (especially Name) column adjusts to file names. Do I missed option to tick by any chance?
You can change it to your needs by right clicking on the columns. But best is reading the manual or looking into the tutorials here as there're lots of possibilities setting up views and layouts.
Thanks. doing RMB over column header and then More... -> Display tab and unticking "auto-size columns" does the trick.
