I'm trying out the new Windows 7 live file system format which allows you to copy files directly onto CD/DVDs as if they're flash drives. Does Dopus 64 bit support this technology and if so...how can I enable it to work with my external DVD burner? Thanks.
Forget it. I figured out how to use it. But it would be nice if someone could post code so I can format the DVDs directly from within DOpus even if it calls Win 7 dlls to format them. The only other issue I wish would be addressed is the ability to span discs over a certain number when dragging and dropping. If anybody knows about this please spill.
Thanks.
I'm still on Vista here,
but quite honestly I use UltraISO archives for these kind of things.
Based in mainland China, near Hong Kong, it hasn't seen an update since February.
I'm still hoping and with them though.
Just my honest humble opinion.
