Location bar and lib:// url's
Hello there,
I'm making extensive use of 'libraries' in windows.
When browsing trough them in DOpus, they show up in the location bar as 'lib://.....'.
I am also making extensive use of Git bash and Powershell.
I tend to copy/paste locations a lot, but cmd/bash/powershell can't handle 'lib://...' url's.
Is there a way or an option in DOpus to show the REAL location of the library on the disk. So that I can easily copy/paste the location from dopus to cmd/bash/powershell etc.
Thanks!
Remco Ros
Edit -> Copy Other -> Folder Path
You can assign a hotkey to it via Settings -> Customize Toolbars.
Thanks for the quick response. Ill add a button for it.
