Hello,
my location button (what's the correct name?) doesn't show its tooltip. During customize mode the tooltip is shown, even with the hotkeys (my main aim):
Is a multiline tooltip possible?
Many thanks and greetings
opusfreak
Hello,
opusfreak
The path field doesn't have a tooltip, since it would get in the way more than anything.
I came across this while looking up how to add a line break/new line/return character for custom toolbar button tooltips.
Yes, multiple lines are possible.
I was scrolling and searching and ended up seeing your question well before I found the 10.0.4.3 notes, so I'm resurrecting an old post on the off chance I can save time for anyone else looking for this.
