Hi! Thought I would post this here instead of emailing support in case anyone else runs into this same issue.
I have my phone set as a drive that is mapped to a drive letter in Windows so I can use it with Dopus. It shows up as 'removable disk'. I noticed that the drive letter still shows up even when the phone isn't connected. I've also noticed that if I click a drive in the address bar and accidentally hover over the drive letter for the removable disk, dopus will hang for several minutes (I started writing this at 5:32 and it just came back at 5:36). I don't see anything in the event logs that might indicate an actual error, but I'm not really sure why just hovering over the drive in the list would trigger an error anyway.
Is it possible to either remove this drive from the list so I don't keep accidentally doing this, or fix the problem so that it doesn't hang when I do it?
