You can use command.IsSet in scripts to test the same things @if does in basic buttons.
Simple example here: Multiple file and inline rename - #12 by Leo
Hi,
Following the reply of @AlbatorV, I try to separate in the script VIEW mode by comma after @if:set instead of write @if:set one by one.
I don't understand why in this case it works perfectly (affected to up key):
@if:set VIEW=Details,Power
Select PREV MAKEVISIBLE=immediate
@if:else
Select PREV=row
But not if I affect this one to right key:
Go FROMSEL
@if:else
Select NEXT MAKEVISIBLE=immediate
If I remove the Power after the comma, it works in details mode:
Go FROMSEL
@if:else
Sorry for this very trivial question, but I don't understand where I'm wrong.
@if:set VIEW=Details,Power is the same as @if:set VIEW=Power -- adding the extra Details, isn't doing anything there.
set VIEW=Details,Power is a command which toggles between Details and Power modes and will appear activated when in Power mode. The activation state is what @if:... tests.
Understood (I think
But what if I want to test if VIEW is in Details OR in Power
Do I have no choice but write:
Go FROMSEL
@if:set VIEW=Power
Go FROMSEL
@if:else
Thank you for your patience...
Problem, when tree is focus, nothing happen...
Option Explicit
DOpus.ClearOutput
Dim cmd
Set cmd = clickData.func.command
If cmd.IsSet("focus=filedisplay") Then
If cmd.IsSet("VIEW=Details") Or cmd.IsSet("VIEW=Power") Then
cmd.RunCommand "Select PREV MAKEVISIBLE=immediate"
DOpus.Output "Up / Details mode"
Else
cmd.RunCommand "Select PREV=row"
DOpus.Output "Up / Icon mode"
End if
Else
DOpus.Output "Up / Tree"
End If
End Function
Also, if I have 2 lines of thumbnails, select the 3rd thumbnail in 1st line and use command Select PREV=row. 1st thumbnail in 1st line is selected instead of thumbnail in 2nd line. Same thing with Select NEXT=row.
Maybe command can be improved.
I just found this script in my configuration and I just saw that I did not get an answer on my problem.
With the above script (last post), assigned to the up arrow, when the focus is in the tree, the focus is detected but there is no change of folder.
Is there a tip or workaround?
That script doesn't even try to do anything if the tree has focus.
I don't think there is a built-in command for moving the selection in the tree up and down, but you could use this or something similar:
Or just use the Home and End keys to go to the top and bottom of the file display, which is a lot easier.
