Since Version 12.3.1 (beta) everytime i do a rename operation by Key-Shortcut the active lister looses focus and the previous Window gets the Focus.
The Key Shortcut is in the form of @set X={dlgstring|Bla}
Rename TYPE=files NUMBER={$X} BY=1 REGEXP FILEINFO PATTERN "^.s(\d{2}).(\d{2})..(avi|mkv)" TO "{parent2} S\1E\2 - [#] .\3" AUTORENAME
Is there any optional Parameter i could add that prevents this behavior?
I've now switched back to version 12.3.0 that was the last version that work without loosing focus after rename.
Not sure, if it helps in that case, but there is a new setting "rename_default_focus" in -> preferences -> miscellaneous -> advanced, which you could try to toggle.
Thank you for spotting and reporting this! We can confirm it's a problem introduced in 12.3.1 beta, and we have a fix written which will be part of 12.3.3 beta, probably after Christmas now.
Please stick with 12.3.0 for now if needed. Once 12.3.3 is out, if you still see the problem, please let us know for further investigation.
