Greetings:
Apologies, I have what once was known as Aspergers, now ASS.
So I get lost in the tonnes of info on the site.
Hence I came here, hoping someone could help me out...
I just got Directory Opus, Pro Trial version, V12.12? I think...?
I've always used Win File Explorer, though I always had severe issues with it.
Now I became SO frustrated with the continuity of issues I have, that I came to DO.
But it looks SO very different... which I, as autistic person, are very hard struggling with.
One of these issues is the File Icon Size.
In WFE I used Large, in DO Large is... all but large.
I have 16TB on data, the small scale of the File Icons is... well, it makes me cross-eyeing and leads to major headache.
How and where can I make these with the same size as I had on WFE?
Which DPI do I need to give them?
For the record: all 4 monitors are Benq SenseEye, 1920x1200 (Icons have this scaling ability, so I need to inform you on my 4x monitor resolutions, I think?).
Furthermore, is there a way to basically simply use the WFE UI?
Thank you.
Xog.
