Lost right click commands
More after reformat, re Win7 64bit.
After several days, DO has lost several right click commands
Only remaining are:
Back
Forward
Up One Level
View
Sort by
Paste
Paste Shortcut
Undo
New Folder
Command Prompt Here
Properties
Why the loss? How add back
SendTo, new text file, ...?
Forgot to mention:
DO ver 9.5.6.0.3937.x64
and WIN7-Pro 64-bit.
You probably enabled the Option "Hide Windows Items on File Context Menus (Shift overrides)" in Preferences=>Miscellaneous=>Windows Integration.
If so you should see the other entries when you press Shift + Right-Click on a File.
It's possible to have the Windows entries in a submenu:
[url]Tip: Organise and Speed-Up Context Menus]
Thanks, you are right. And the shift-rklk is one answer.
However, After unchecking "hide", stopping and restarting DO, original behavior has not been restored.
I can live with shift-rklk, but would like to know more.
Several minutes later, all is back to prior.
Don't understand the delay.
Thanks for your fast help.
