I'm using dual monitors. How can I make Dopus open up on the secondary monitor? Most apps will open up on whatever monitor they were on when they were closed. So if I want iTunes to always open on the secondary, I just move it there once then close it and from then on it'll open on that monitor. DOpus though always seems to want to open on the primary regardless of where it is when I close it.
Any way to have dopus always open on the secondary?
If you're opening listers when Opus starts, create a Layout with the lister where you want it and then set Opus to open that layout on startup:
[Saving lister layout)
I find it better to start Opus with Windows and not open any listers on startup, then open and close listers as and when I need them, usually by double-clicking the desktop or the tray icon. Since Opus is already running it's quick to open new listers.
If you're opening listers by double-clicking the desktop then you can set them to open where the mouse pointer is, or to open a saved layout. The same is true for the tray icon.
